[progress Communities] [progress Openedge Abl] Forum Post: Re: Remote Connect To Access Db...
  • Thread starter Thread starter Paul Koufalis
P
Paul Koufalis
I don't think the AdminServer port matters to your DB conx. I think the rest makes sense. It's hard to debug with just a little bit of information in your post. When you run the "FOR EACH odbc_table" and get the "could not find file" error, did you validate that the _odbcsrv.exe spawned (sorry I forget the exact name of the executable)? And what is in dataserv.lg? Up the logging level on the odbc ds and see what it spits out. How did you create the SH? Is it from a previous version? At some point you had to pull the schema from Access.
