Mike Fechner
Simply put, there is no room for them in the r-code. The next major change in r-code format is possible with OpenEdge 12. :-( We have built a routine that extracts them from source code (either using proparse or xref) and makes them available at runtime in .annotation files.I believe that's as good as you can get with OE11.
