[Progress Communities] [Progress OpenEdge ABL] Forum Post: RE: Really need help to handle "BIG" 40~70kb file to send to webservice.
O
OctavioOlguin
ok!!!.. I'll try... Thanks Matt I figured out about increasing 20% to the current using... as I found a KB about -yd to find current max usage... but as you mention 128kb default, that same kb states that beign the default... Just tought that appserver agent was different... The problem now is reduced to what the appservice receives...
