Marco Aurelio
hi, changing to XML-NODE-NAME "Value2" worked fine . DEFINE TEMP-TABLE Value1 NO-UNDO NAMESPACE-PREFIX "" XML-NODE-NAME "Value1" SERIALIZE-NAME "Value1" FIELD Value1_Text AS DECIMAL XML-DATA-TYPE "decimal" XML-NODE-NAME "Value1_Text" XML-NODE-TYPE "TEXT" SERIALIZE-NAME "Value1_Text" FIELD Height_id AS RECID XML-DATA-TYPE "long" XML-NODE-NAME "Height_id" XML-NODE-TYPE "HIDDEN" SERIALIZE-NAME "Height_id" FIELD Altitude_id AS RECID XML-DATA-TYPE "long" XML-NODE-NAME "Altitude_id" XML-NODE-TYPE "HIDDEN" SERIALIZE-NAME "Altitude_id". DEFINE TEMP-TABLE Value2 NO-UNDO NAMESPACE-PREFIX "" XML-NODE-NAME "Value2" SERIALIZE-NAME "Value2" FIELD Value2_Text AS DECIMAL XML-DATA-TYPE "decimal" XML-NODE-NAME "Value2_Text" XML-NODE-TYPE "TEXT" SERIALIZE-NAME "Value2_Text". DEFINE DATASET newvalue for value1, value2. create value1. create value2. dataset newvalue:write-xml("file","test.xml",true,?,?,?,?).
