P
Peter Judge
You can probably ignore it but think about what it’s telling you – and that is that there is potential for error/ambiguity in mapping the XML to the temp-tables and fields. We (ABL) can be smart but only really so smart. If you have very complex XML that doesn’t match well to temp-tables I’d recommend looking at the SAX parser and manually mapping the stuff.
