B
Brian K. Maher
Markell, Those are startup parameters. They go either on the command line or in a .pf which which then goes on the command line. Examples... prowin32.exe -clientlog c:\mystuff\client.log -logginglevel 4 -logentrytypes or create a file containing those parameters, one per line and save the file as bubba.pf then the command line would be prowin32.exe -pf bubba.pf Since you are new I would strongly recommend that you open a support case with us and we can go through all the options for debugging. You have lots of options. Brian
