V
Valeriy Bashkatov
Fisrt, check that AdminServer is started: proadsv -q Second, check that fathom (aka management) is started: fathom -query If both are started, then check port 9090 in the firewall. What OS are you use? if you use localhost for connect then it seems to me it it is Windows, right?
