P
PeterWokke
Hi Simbu, First you have to setup the database within OpenEdge Management. The admin server has to run (services). Fahtom can than be started on its default port 9090. Within the configuration you have to allow sql to a port number. Depending the 32bit or 64bit of your Progress install you can than configure an ODBC connection to the assigned port. Peter
