Rajkumar Mateti
Hi Abir, Try with following steps Before generating the application XML. 1) Navigate to Application settings. 2) Click on Edit button. You can find "Core objects" and "Dependent Objects" sections. 4) Remove those object from Selected objects list from Dependent Objects section. 5) Add those objects from Available Objects to Selected objects in Core objects section. 6) Save the application definition. 7) Generate Application XML and then Import application. Thanks, Rajkumar
