[Progress Communities] [Progress OpenEdge ABL] Forum Post: RE: Pro2 - upgrade dbs from 10.2b to 11.7
  • Thread starter Thread starter Valeriy Bashkatov
V
Valeriy Bashkatov
Hi goo, I'm afraid I didn't understand the process you described. Why do you need to do two restores? If I understand your task correctly, then you just need to update the database to 11.7.5 with migration to another server with the same OS? All you need to do is stop the source database, make a backup, copy and restore it to another server, and get started. If the repl database also needs to be converted and moved, then do it. And then change the connection parameters in Pro2 if the hostname of the source database has changed. After that, everything will start and the replication process will continue without problems. You do not need to re-do the primary synchronization (bulkload).
