C
cverbiest
Which RTB version are you using ? the path seems to indicate rtb 10.1c. In a recent RTB version I'd check if the automation toolkit can do it. AFAIK you need to for each rtb_object where wspace-id = myworkspace: run rtb_nams to get the paths. create the directories , not sure if it's required but it's in my code. run rtb_extract_object to extract. end. Don't know how to attach code here so I'll mail something .
