[progress Communities] [progress Openedge Abl] Forum Post: Re: Passing A Dataset As A Parameter
marian.edu
afraid passing datasets as parameters are perfectly possible, using by-reference is always welcome only you have to be aware you work on the same object and in your case there might well be temp-tables in it that have tracking-changes turned on so you kinda need to handle that :) if you’re not doing any empty-table on any of it’s temp-tables then there might be a call to fill using empty mode instead of append, just a guess though Marian Edu Acorn IT www.acorn-it.com www.akera.io +40 740 036 212
