I
Irfan
Darek, You did the right thing and thats the way it has to work. Can you please raise a case with tech support ? Alternatively, as you said you were on 11.7.1, if you can create a new PASOE Instance with the below command it has to create you a Prod Install PASOE Instance. pasman create -Z prod -p -P -s
