		Roger Blanchard
>> If you are running on Windows, then I'd recommend getting on a recent SP if possible (I've been fairly happy with OE 11.7.4 and 11.7.5). We are running 11.7.5, >> Also on windows - remember to create anti-virus (defender) exclusions, and disable "data execution prevention" (DEP). We just did that yesterday and will see what happens. >> Small note about the DEP - if you're using 3rd-party components, make sure those are DEP compliant as well. If they're not, those components are likely to originate the crashes. The crashing is upon session startup but not all the time. It is typically happening as users are attempting to login and another session is attempting to start.
