Thanks Irfan. I created the case ( #00426507 ). Thanks also for that KB. I had wondered in the past whether a single tomcat server would be able to host multiple ABL applications. In the OEE U/I these two logical levels seemed inseparable. While there is an HTML table of "applications", there is only one entry in the table and it has the same name as the instance. There are no operations available in OEE (as far as I can tell) that indicated an actual one-to-many relationship; I thought the table of "applications" was just a U/I design problem. Thanks for the tip, David
