[progress Communities] [progress Openedge Abl] Forum Post: Re: Pas To Emulate State-reset...
  • Thread starter Thread starter Irfan
I
Irfan
David, We have a bug here in the Product and documentation. We have to fix the sessionStartup part for State-reset based applications. I can log a bug for it, but if you would like to raise a TS case so that you can have a track it then please do. So as an alternative, you can run two different ABL Applications in a single PASOE Instance. This gives the ability to run two different session-managers which can have their own event procedures, PROPATH, database configurations and agents. Here is the quick kbase for you on how to create ABL Application - knowledgebase.progress.com/.../How-to-create-multiple-ABL-applications-in-one-single-PASOE-instance
