[progress Communities] [progress Openedge Abl] Forum Post: Re: Pas To Emulate State-reset...
  • Thread starter Thread starter Blake Stanford
B
Blake Stanford
We too run session level processing, instantiate session persistent procedures from the startup program. We have processing in our activate/deactivate procedures which test for the existence of them and initializes them if they don't exist. I'm going to look at them further and make sure that it is all working correctly. I agree it is not as simple as it may migrate to PAS as it should be, at least if one tries to use one instance for both state-reset and state-free. We may end up starting 2 instances, 1 for our state-reset connections and one for our state-free connections. I believe there is a way in which one can put 2 oeabl web applications under the same instance, each having its own set of abl agents I'm experimenting with that also.
