I
Irfan
agentListenerTimeout - When the session manager starts a Multi-session Agent, it creates a listening socket and passes that port number to the agent as a startup argument. After startup, the agent process completes the network initialization based the timeout value specified for this property. So, this only affects when you startup the PASOE Instance. You have to modify this value if your agent does not start in the given time. Also the Idle session timeout means the session-manager sessions and not the MS-Agent session. All the other properties are as mentioned in the document. And yes, these were there from the beginning but we never suggested them to customers, hence the idleResourceTimeout was always disabled. If the documentation is not clear, then we have to fix it. Will log a bug for it.
