[progress Communities] [progress Openedge Abl] Forum Post: Re: Pas Sessions Never Stopped...
  • Thread starter Thread starter ManfredBerthold
ManfredBerthold
These timeouts are really confusing, spending a lot of time with them. IdleResourceTimeout should now work (i'm using 11.6.3.22) Clarifying Information in KB 000077758: Notes The idleResourceTimeouts which involve idleSessionTimeout,idleConnectionTimeout and idleAgentTimeout were working from beginning but we never completely tested it and we did not have confidence on how it works, that was the reason we mentioned as ‘NOT IMPLEMENTED !’. When we tested the same in 11.6.3 and 11.7.1 we observed that it is working fine and there no repercussions. Now that we see it working fine, we started suggesting others to use it. If you want to try out in a 11.6.3 or 11.7.1 test environment, then you can enable idleResourceTimeout and idleAgentTimeout to a minimum value and you should see that the agent gets terminated in the given period.
