[Progress Communities] [Progress OpenEdge ABL] Forum Post: RE: PAS error for tcman - The instance alias name not registered - oepas1
Gotcha. Thanks for the help. I can see that the copy of tcman in the instance directory would bypass some of the difficulty I was having. I did find the instances file as you pointed out ("instances.windows"). By updating that, I was able to get the original tcman command to work as well. Any chance of adding something into tcman that will run the tomcat java process as LocalSystem instead of with user credentials? What I'm doing now is I have to download pstools and run "psexec -s" to ensure that, when tomcat runs from tcman commands, it runs the same way it would when started from OEE.
