[Progress Communities] [Progress OpenEdge ABL] Forum Post: RE: PAS deployment of a new ABL application in the same tomcat instance
  • Thread starter Thread starter Irfan
I
Irfan
When would you like to reload your r-code ? If it is development then you have two options 1. terminate the agent, when you run a new request then it will start a new agent and will load the new r-code. 2. terminate all free MS-Agent sessions, this will terminate all free sessions and when the new request comes it will start a new session and it will load the r-code. You can do both of them using oemanager or JMX API's.
