[Progress Communities] [Progress OpenEdge ABL] Forum Post: RE: PAS deployment of a new ABL application in the same tomcat instance
  • Thread starter Thread starter Peter Judge
P
Peter Judge
>It was a bit of a challenge to work thru this stuff. First of all, when multiple ABL applications and multiple ABL webapps >are in play, the PDSOE does the *least* helpful thing it can possibly do when it publishes your code modules into > "catalina.base"\openedge. Essentially this causes all code, whether related or not, to be "flattened" out into the same > massive code directory without any organization. That particular directory is shared for the entire PAS instance. Agreed. We have plans/backlog items to make this better. You can do a couple of things in the interim - In your instances, there should be an ablapps/ / folder already (in 11.7 something, maybe .0). I’d add an openedge/ folder to that, and add that folder to PROPATH in the instance config. Now you should have a default propath that looks something like ${CATALINA_BASE}/webapps/ROOT/WEB-INF/openedge, ${CATALINA_BASE}/ablapps/oepas1/openedge, ${CATALINA_BASE}/openedge, ${DLC}/tty (assuming an ablapp of oepas1 and the default ROOT webapp) The ${CATALINA_BASE}/openedge directory is for common libraries/code like framework code. The ${CATALINA_BASE}/ablapps/oepas1/openedge folder is for this-application’s code (business logic) The ${CATALINA_BASE}/webapps/ROOT/WEB-INF/openedge folder is for service interfaces into that business logic - In PDSOE set your publish location to ${CATALINA_BASE}/ablapps/oepas1/openedge
