Stefan Marquardt
Yes, both are installed. But this is from the 32bit adminserver logfile, running on a separate port. TCP 0.0.0.0:20931 [java.exe] TCP 0.0.0.0:20941 [java.exe] And at the end it's only starting the 2 configured appservers in the 32bit version. [2017/03/02@09:16:55.174+0100] [3] [AdminServer] License check status: Plugin installed. (ADMMsg002) (7438) [2017/03/02@09:16:55.176+0100] [2] [PAS] Using default properties file C:\Progressx86\OpenEdge116\properties\pasmgr.properties. (8249) [2017/03/02@09:16:55.186+0100] [3] [AdminServer] Plugin.PAS: Plugin installed. (ADMMsg002) (7440) [2017/03/02@09:16:55.187+0100] [2] [AdminServer] Installing plugin: Plugin.Database (7432) [2017/03/02@09:16:55.201+0100] [0] [AdminServer] * License check status: Plugin not licensed. (ADMMsg037) (7438) [2017/03/02@09:16:55.201+0100] [0] [AdminServer] * Plugin.Database not installed: Plugin not licensed. (ADMMsg037) (7439) [2017/03/02@09:16:55.201+0100] [0] [AdminServer] * Failed to install plugin Plugin.Database. (7433) [2017/03/02@09:16:55.201+0100] [2] [AdminServer] Installing plugin: Plugin.SonicMQAdapter (7432) [2017/03/02@09:16:55.201+0100] [3] [AdminServer] License check status: Plugin installed. (ADMMsg002) (7438) [2017/03/02@09:16:55.207+0100] [3] [AdminServer] Plugin.SonicMQAdapter: Plugin installed. (ADMMsg002) (7440) [2017/03/02@09:16:55.207+0100] [3] [AdminServer] Plugins installed. (7411) [2017/03/02@09:16:55.208+0100] [3] [AdminServer] AdminServer thread started. (7412) [2017/03/02@09:16:55.208+0100] [3] [AdminServer] AdminServer object instantiated. (7425) [2017/03/02@09:16:55.208+0100] [2] [AdminServer] Starting plugin Plugin.Management. (7434) [2017/03/02@09:16:55.208+0100] [1] [AdminServer] Admin server initialization completed. (7428) [2017/03/02@09:16:55.208+0100] [3] [AdminServer] Started plugin Plugin.Management. (7435) [2017/03/02@09:16:55.208+0100] [2] [AdminServer] Starting plugin Plugin.System. (7434) [2017/03/02@09:16:55.208+0100] [3] [AdminServer] Started plugin Plugin.System. (7435) [2017/03/02@09:16:55.208+0100] [2] [AdminServer] Starting plugin Plugin.UBPropMgr. (7434) [2017/03/02@09:16:55.208+0100] [3] [AdminServer] Started plugin Plugin.UBPropMgr. (7435) [2017/03/02@09:16:55.208+0100] [2] [AdminServer] Starting plugin Plugin.WebSpeed. (7434) [2017/03/02@09:16:55.208+0100] [3] [AdminServer] Started plugin Plugin.WebSpeed. (7435) [2017/03/02@09:16:55.208+0100] [2] [AdminServer] Starting plugin Plugin.WSA. (7434) [2017/03/02@09:16:55.208+0100] [3] [AdminServer] Started plugin Plugin.WSA. (7435) [2017/03/02@09:16:55.208+0100] [2] [AdminServer] Starting plugin Plugin.AppServer. (7434) [2017/03/02@09:16:55.208+0100] [3] [AdminServer] Started plugin Plugin.AppServer. (7435) [2017/03/02@09:16:55.209+0100] [2] [AdminServer] Starting plugin Plugin.WebServerRemote. (7434) [2017/03/02@09:16:55.209+0100] [3] [AdminServer] Started plugin Plugin.WebServerRemote. (7435) [2017/03/02@09:16:55.209+0100] [2] [AdminServer] Starting plugin Plugin.ActiveMQS. (7434) [2017/03/02@09:16:55.209+0100] [3] [AdminServer] Started plugin Plugin.ActiveMQS. (7435) [2017/03/02@09:16:55.209+0100] [2] [AdminServer] Starting plugin Plugin.ODBCDataServer. (7434) [2017/03/02@09:16:55.209+0100] [3] [AdminServer] Started plugin Plugin.ODBCDataServer. (7435) [2017/03/02@09:16:55.209+0100] [2] [AdminServer] Starting plugin Plugin.REST. (7434) [2017/03/02@09:16:55.209+0100] [3] [AdminServer] Started plugin Plugin.REST. (7435) [2017/03/02@09:16:55.209+0100] [2] [AdminServer] Starting plugin Plugin.AIA. (7434) [2017/03/02@09:16:55.209+0100] [3] [AdminServer] Started plugin Plugin.AIA. (7435) [2017/03/02@09:16:55.209+0100] [2] [AdminServer] Starting plugin Plugin.RemoteCommander. (7434) [2017/03/02@09:16:55.210+0100] [3] [AdminServer] Started plugin Plugin.RemoteCommander. (7435) [2017/03/02@09:16:55.210+0100] [2] [AdminServer] Starting plugin Plugin.WSMessenger. (7434) [2017/03/02@09:16:55.210+0100] [3] [AdminServer] Started plugin Plugin.WSMessenger. (7435) [2017/03/02@09:16:55.210+0100] [2] [AdminServer] Starting plugin Plugin.NameServer. (7434) [2017/03/02@09:16:55.210+0100] [3] [AdminServer] Started plugin Plugin.NameServer. (7435) [2017/03/02@09:16:55.210+0100] [2] [AdminServer] Starting plugin Plugin.PAS. (7434) [2017/03/02@09:16:55.211+0100] [3] [AdminServer] Started plugin Plugin.PAS. (7435) [2017/03/02@09:16:55.211+0100] [2] [AdminServer] Starting plugin Plugin.SonicMQAdapter. (7434) [2017/03/02@09:16:55.211+0100] [3] [PAS] Starting Pacific Application Server instance initialization [2017/03/02@09:16:55.211+0100] [3] [AdminServer] Started plugin Plugin.SonicMQAdapter. (7435) [2017/03/02@09:16:55.218+0100] [3] [PAS] Finished Pacific Application Server instance initialization
