L
Libor Laubacher
Generally when adding a new product one needs to install it to make sure all binaries, registry, properties, config files etc are in place. There are exceptions like for example "installing" Enterprise DB while Workgroup is present and/or Replication Plus while already having a Replication etc. There you can install the list of products somewhere else and swap progress.cfg (so you won't disrupt your production if this is live environment). So if the product has been removed via license update utility and now for whatever reason on the same install you need it back you can do the same approach (install on another machine and replace cfg, or if you have a copy of it prior the product removal ...). There is still an install, but no disruption to your live production environment (if this is a production).
