[progress Communities] [progress Openedge Abl] Forum Post: Re: Not Able To Setup Pacific...
  • Thread starter Thread starter Sanjeev Reddy
Sanjeev Reddy
Hi Mitesh, To solve OpenEdge Explorer problem after installing 11.6.2 service pack follow the instructions mentioned by Anil. Once the problem is solved, let us know how you deployed (i.e. deploy as ROOT or WebApp) your application to PAS. If you didn’t change any deployment options while creating New ABL Web App project, then deployment is ROOT by default. In this case the URL to access the service is: http:// : /rest/ . If your application is deployed as WebApp, then the URL to access the service is: http:// : / /rest/ / . You can check the service URI from edit service dialog before checking in browser. Thanks, Sanjeev.
