P
Peter Judge
JSON doesn't have a binary data type, so you will always get some form of character data. As Frank mentions, the simplest way is to make sure that the dataset/temp-tables have the appropriate schema (so a RAW field). If you want to dynamically create the temp-tables, you will have to use a schema (XML or hand-written JSON). -- peter
