[progress Communities] [progress Openedge Abl] Forum Post: Re: Job Does Not Stop
  • Thread starter Thread starter Wim
W
Wim
Deer Pradeep, We are on private cloud version 4.1.1.0 (it is in production sinds july 1th 2016). (We have 185 users) It was a normal import, and was cancelled bij me after 35 minutes. However it look as though the cancelling had no affect, because 5 hours later is was ready on processing 64.000 records. Hope this information helps. Regards, Wim Van: Pradeep Kagithalagudem [mailto:bounce-pkagitha@community.progress.com] Verzonden: maandag 18 juli 2016 06:57 Aan: TU.Rollbase@community.progress.com Onderwerp: RE: [Technical Users - Rollbase] Job does not stop Update from Progress Community Pradeep Kagithalagudem You are trying correct way to stop. The import job should get cancelled. Can you provide details about the Rollbase version you are using and import job is normal or bulk import? View online You received this notification because you subscribed to the forum. To unsubscribe from only this thread, go here . Flag this post as spam/abuse.
