[progress Communities] [progress Openedge Abl] Forum Post: Re: Int Conversion In For Each...
  • Thread starter Thread starter Dominik Loewenstein
Dominik Loewenstein
[quote user="Brian K. Maher"] Hi Dominik, Are you using the -debugalert startup parameter? If so, try removing it. Brian [/quote] Yes, but removing it didn't changed anything [quote user="George Potemkin"] _UserTableStat will give you the number of records the query retrieved before it stopped. So you will know a record to suspect. [/quote] When i debug, the first record causes the problem [quote user=" Laura Stern"] Is the program crashing? I.e., Do you get a procore/protrace file? [/quote] nope, i get no protrace file has anybody tryed to reconstruct the problem ?
