[progress Communities] [progress Openedge Abl] Forum Post: Re: Installing Oe Bpm With Eap
  • Thread starter Thread starter kopatra
K
kopatra
Hi Fernando, I do not think, installer have reached till validating the jboss version with reference to the attached error screen shot. It seems installer has failed to validate Jboss path. We need to pass the base path of the Jboss in the installer i.e for reference please check if /bin folder and "jar-versions.xml" are available under the path you have specified. Installer will pop up the invalid version error message incase version does not match the required/supported version. Thanks Kousik
