[progress Communities] [progress Openedge Abl] Forum Post: Re: How To Start With Appsolute...
  • Thread starter Thread starter asthomas
asthomas
The download actually contains a file called apache-ant-1.9.4.zip - which contains a version of Ant 1.9.4 with the external libraries included. Check in the "lib" directory. There you will find the extra libraries, including a copy of PCT version 187. You can either use this, or if you want to use a newer version of Ant, download and update this as per the instructions in the docs. I would recommend that once you have unpacked it, that you then set ANT_HOME for your environment to point to ths Ant installation.
