[progress Communities] [progress Openedge Abl] Forum Post: Re: How To Start With Appsolute...
  • Thread starter Thread starter asthomas
asthomas
well, I always set this so that I can test from Eclipse and so that the Ant editor can successfully syntax check the Ant scripts if I make changes to them. If you are not planning on using the toolkit directly from Eclipse, then I suppose you can skip this step. It is nice and easy to test the scripts, config files etc by running directly from Eclipse. So we usually do this as part of the initial setup.
