[progress Communities] [progress Openedge Abl] Forum Post: Re: How To Pass Parameters To...
  • Thread starter Thread starter Dustin Grau
Dustin Grau
"I am not sure how to check if the MyCount exists in the service or not." Let's try this... 1) Download the catview.html file at this location: raw.githubusercontent.com/.../catview.html 2) Copy that file into your project's PASOEContent/static/ directory and allow PDS to publish to your PAS instance. 3) Visit the page (should be accesible at localhost:8810/.../catview.html) 4) If the page cannot self-detect the proper catalog URL, then provide te direct path to your .JSON catalog file. Based on the URL you provided, I would guess it to be this: localhost:8810/.../psLogGUIService.json 5) Press the "Load Catalog" button and you should get back a visual representation of your data object catalog. From here you can locate the MyCount method in the psLogHdr service, and execute a request against that endpoint.
