C
curtiscooper
Thanks. I will check out that link. If I could pass in parameters and do client side processing, that would be ideal. I am not sure on the transport.read method. I didn't do anything custom with that ; I just have the class generated when creating an ABL Web App project in PDSOE. I am going over the JSD setup again to see if I missed something. The error I get in when doing server side is : Failed to load resource: the server responded with a status of 404 () progress.all.js:12498 [Deprecation] Synchronous XMLHttpRequest on the main thread is deprecated because of its detrimental effects to the end user's experience. For more help, check https://xhr.spec.whatwg.org/. progress.data.AuthenticationProvider._openRequestAndAuthorize @ progress.all.js:12498 :8810/psLogGUI/rest/psLogGUIService/psLogDtl/MyCount?filter=%7B%22skip%22%3A0%2C%22top%22%3A5%7D&_ts=150834865-6640993464-4 Failed to load resource: the server responded with a status of 404 () Link failing localhost:8810/.../MyCount localhost_access-log : shows 404 error, but it tells me nothing 0:0:0:0:0:0:0:1 - - [18/Oct/2017:13:44:22 -0400] "OPTIONS /psLogGUI/rest/psLogGUIService/psLogHdr/MyCount?filter=%7B%22skip%22%3A0%2C%22top%22%3A5%7D&_ts=150834865-6640993464-5 HTTP/1.1" 200 - 1 0:0:0:0:0:0:0:1 - - [18/Oct/2017:13:44:22 -0400] "PUT /psLogGUI/rest/psLogGUIService/psLogHdr/MyCount?filter=%7B%22skip%22%3A0%2C%22top%22%3A5%7D&_ts=150834865-6640993464-5 HTTP/1.1" 404 - 32 0:0:0:0:0:0:0:1 - - [18/Oct/2017:13:44:22 -0400] "PUT /psLogGUI/rest/psLogGUIService/psLogDtl/MyCount?filter=%7B%22skip%22%3A0%2C%22top%22%3A5%7D&_ts=150834865-6640993464-4 HTTP/1.1" 404 - 34 0:0:0:0:0:0:0:1 - - [18/Oct/2017:13:44:22 -0400] "OPTIONS /psLogGUI/rest/_oeping?_ts=150834865-6640993464-6 HTTP/1.1" 200 - 0 0:0:0:0:0:0:0:1 - - [18/Oct/2017:13:44:22 -0400] "GET /psLogGUI/rest/_oeping?_ts=150834865-6640993464-6 HTTP/1.1" 200 39 12 0:0:0:0:0:0:0:1 - - [18/Oct/2017:13:44:22 -0400] "OPTIONS /psLogGUI/rest/_oeping?_ts=150834865-6640993464-7 HTTP/1.1" 200 - 1 0:0:0:0:0:0:0:1 - - [18/Oct/2017:13:44:22 -0400] "GET /psLogGUI/rest/_oeping?_ts=150834865-6640993464-7 HTTP/1.1" 200 39 5 If I only have a few records, it works. However, I assume this is only because there are few enough records such that myCount function is not running.
