[progress Communities] [progress Openedge Abl] Forum Post: Re: How To Get Instantiating...
  • Thread starter Thread starter Laura Stern
L
Laura Stern
Using SOURCE-PROCEDURE from within a class is not really "sanctioned" behavior. It was never intended to work and the ability to do this may some day go away! As Mike said, you should have a method/property in the class that the caller can use to set the handle to the caller if that is necessary.
