[progress Communities] [progress Openedge Abl] Forum Post: Re: How To Copy Memptr To/from A...
  • Thread starter Thread starter ankitshukla
ankitshukla
If you want to use you xml to save into LONGCHAR then why don't you use p_doc:SAVE("longchar":U,i_xml_string). it will give you your xml into longchar after it you can write it into a file (if you want ) copy-lob from i_xml_string to file "test.xml".
