K
kuhles
Hi @jhensley, thanks for answering. I have an already working OpenEdge Progress Database, and i am trying to connect it to the Hybrid Data Pipeline so that I can connect the database to things Like progress Kinvey for Apps. I did my current installation of the Hybrid Data Pipeline using the Single Node setup, Since the load balancer is only talked about in the cluster setup, is my setup wrong? If the load balancer config exists in my current setup can you tell which folder it usually lies in. Regards Kuhle
