[progress Communities] [progress Openedge Abl] Forum Post: Re: How To Configure Dsn On...
  • Thread starter Thread starter Libor Laubacher
L
Libor Laubacher
>> However my concern is I have a MSS sql database on window machine and my Openedge database is on linux server. I want to access MSS sql database from linux server to window machine.. Here my concern is : 1. which driver is needed on Linux side ? 2. what configuration required in odbc.ini or odbcinst.ini ? Please share.. << You have MS SQL on windows. You have MS SQL Dataserver and schema holder on Windows. From Linux you simply connect to schema holder and dataserver on Windows. You do not need any driver on Linux. You need C/N license on your Linux.
