[Progress Communities] [Progress OpenEdge ABL] Forum Post: RE: How to backup Kendo projects
Anil Kumar
Hi, Project generated from Kendo UI Builder environment is a node based project and it has bunch of node modules in them. List of all the modules/packages are available in package.json file which is located in project folder. Considering above, we can remove node_modules directory and checkin/share rest of the folder structure. I.e., once we have this structure, running directly from node environment like npm install will bring all required files into project. Alternatively, we can perform build or preview operations in KUIB to generate required artifacts. Note: We haven't checked in KUIB project to SVN for daily checkins. However, above mentioned is one way we share KUIB projects among. Hope this helps. Thanks and Regards, Anil Kumar
