[progress Communities] [progress Openedge Abl] Forum Post: Re: How To Avoid Duplicated Records
  • Thread starter Thread starter Siddeshwar
Siddeshwar
Hi caylali, The above code is working fine for me. Can you check the integration name for Object is 'Merchant' and field integration name is 'name' for the field that you want check condition. Thanks, Siddeshwar.
