[progress Communities] [progress Openedge Abl] Forum Post: Re: How To Avoid Duplicated Records
  • Thread starter Thread starter Mani Kumar
Mani Kumar
Hi Cayla, I understand that you might be using "Create New Record" trigger on the related objects.In that respect is no out of the box way to perform this in your use case. You can try below options: 1. Include Trigger script to validate the existing records before creating. Or 2. Include a field level validation NOT to allow duplicates. Please correct me if my understanding is not correct. Regards, Mani.
