[Progress Communities] [Progress OpenEdge ABL] Forum Post: RE: How does comparing BLOB fields work?
  • Thread starter Thread starter jbijker
jbijker
Is the BLOB field living on a DB field? If so you first need to COPY-LOB it to a longchar or whatever other variable because ABL won't fetch the BLOB data using a normal FIND. COPY-LOB will go and fetch the BLOB properly from the DB into memory.
