[progress Communities] [progress Openedge Abl] Forum Post: Re: Help Required On Writing A...
  • Thread starter Thread starter smat-consulting
smat-consulting
Marco's note is very true, of course - as long as you don't exclude fields from the buffer-compare. As written above, no buffer-compare is needed. Also, I would advise to make the assign of the three fields following the buffer-copy part of the buffer-copy; and I always recommend to always prefix any field with the table-name. That way, if somebody at some other time adds a variable with the same name, the assign will still assign the value to the record-field, rather than the variable. (Happened before, took three days to find that bug!)
