O
oedev
Write a code generator that generates the code for you, by reading through the tables in your database. Some example pseudo-code (not syntax checked); for each _file: output to value (_file.-file-name + "trigger.p"). put unformatted "trigger procedure for write of " + _file.file-name + " old buffer beforetablebuffer" skip. /* rest of the required code */ output close. end.
