[progress Communities] [progress Openedge Abl] Forum Post: Re: Generate Auto Fields
  • Thread starter Thread starter Karthikeyan Bhaskaran
K
Is a relationship defined between the two objects? Then you can update field value by writing a script. Can you explain your use case? Do you want to only update (related) records in the other object?
