[progress Communities] [progress Openedge Abl] Forum Post: Re: Filter A Lookup Field...
  • Thread starter Thread starter Chandrasekhar Gontla
C
Hi Iram, As per documentation, rbf_setViewSelector is not applicable for lookup field which is rendered as picklist. Doc Info: "This function sets the view ID used by a lookup field for both auto-complete and pop-up selectors. Important: This function cannot be used on dependent lookups. This function only apply for "Selector" style lookup fields." But, we have a way to set a view for lookup field of type picklist. > Go to design this page. > Open properties of lookup field. > Select the view that you want and save it. > Now the picklist will show the records which are part of that view only. Hope this helps. Find attached screen shot. Thanks and Regards, Chandu.
