Matt Baker
This is a bug with tcman returning an improperly encoded JSON responses when there are multiple lines returned when errors are discovered in the log file, and/or when there are quotes embedded in the log file data. The first part of the error is indicating that OEM handled it as best it could, but basically, but the response from tcman is unparsable due to the bad encoding. I will try to find a bug number for you. In the meantime, check the agent log file and catalina.log file for the real error.
