John Miller
Hi Archana, It is not necessary to change the URL (soap_server_binding_url) in the CDD. This URL is only a place holder for what would be added to the WSDL, if the WSDL is created inside the Corticon Deployment Console. No other part of Corticon will look at the URL inside the CDD file. The WSDL generated from the Deployment Console is more or less sample code that can be used by a customer to execute against a Decision Service on a remote server. The WSDL is only used to connect and pass data to a servlet on a remote server; it is not used internally in the Corticon Server during execution against a Decision Service. With that said, if you want to use the WSDL to connect to your remote server against https using SoapUI (for example), then you will need to change the URL inside the WSDL since SoapUI will need the proper URL to connect to the server. I hope this helps. -John
