[Progress Communities] [Progress OpenEdge ABL] Forum Post: RE: Easiest way to check OpenEdge database schema compatibility ?
  • Thread starter Thread starter mollyfed
mollyfed
Hey. So what are you going to do if they don't match? Try and get them to match with an Incremental Df? ;-) Not sure this helps, but was thinking it and if its the case, then doing a Inc DF is probably quickest in the long run. Molly PS. Oh, this also might help: knowledgebase.progress.com/.../P15443
