[Progress Communities] [Progress OpenEdge ABL] Forum Post: RE: Easiest way to check OpenEdge database schema compatibility ?
  • Thread starter Thread starter Mike Fechner
Mike Fechner
10.2C? Sent from Nine Von: teppo_55 Gesendet: Dienstag, 12. Dezember 2017 8:14 vorm. An: TU.OE.RDBMS@community.progress.com Betreff: [Technical Users - OE RDBMS] Easiest way to check OpenEdge database schema compatibility ? Update from Progress Community teppo_55 To OpenEdge db experts! What is the easiest way to check database schema compatibility? I know incremental df technique and proutil describe. I'd like to have a proutil option to get a number based on all _File-_CRC values. Is there such option, or what is the easient technique to compare database schemas (version 10.2C)? Regards - teppo. View online You received this notification because you subscribed to the forum. To stop receiving updates from only this thread, go here . Flag this post as spam/abuse.
