[Progress Communities] [Progress OpenEdge ABL] Forum Post: RE: Deploy incremental ABL Web Application
  • Thread starter Thread starter Derek Lord
Derek Lord
Hi Irfan, I used a new VM, Installed 11.7.1, installed our app, deployed the initial war and then the incremental. The instance is not running and I am the only user on the VM, no files open for edit. This is the full log from the incremental deployment. proenv>cd C:\lttrn\api proenv>LT1800Test\bin\deploysvc -a LumberTrack -v -g LumberTrack_1801_incr.war.zip deploysvc verbose: deploying service artifact LumberTrack_1801_incr.war.zip trace: file unzip : c:\lttrn\api\LT1800Test\webapps\LumberTrack\static\commonPageFooter.html trace: file unzip : c:\lttrn\api\LT1800Test\webapps\LumberTrack\static\commonPageHeader.html trace: file unzip : c:\lttrn\api\LT1800Test\webapps\LumberTrack\static\commonStyle.css trace: file unzip : c:\lttrn\api\LT1800Test\webapps\LumberTrack\static\home.html trace: file unzip : c:\lttrn\api\LT1800Test\webapps\LumberTrack\static\home.jsp trace: file unzip : c:\lttrn\api\LT1800Test\webapps\LumberTrack\static\index.jsp trace: file unzip : c:\lttrn\api\LT1800Test\webapps\LumberTrack\static\ServerStatus.html trace: file unzip : c:\lttrn\api\LT1800Test\webapps\LumberTrack\static\serverstatus.js trace: file unzip : c:\lttrn\api\LT1800Test\webapps\LumberTrack\WEB-INF\openedge\FinancialAmounts.r trace: file unzip : c:\lttrn\api\LT1800Test\webapps\LumberTrack\WEB-INF\openedge\Inventory.r trace: file unzip : c:\lttrn\api\LT1800Test\webapps\LumberTrack\WEB-INF\openedge\InventoryHandler.r trace: file unzip : c:\lttrn\api\LT1800Test\webapps\LumberTrack\WEB-INF\openedge\LtGlobal.r trace: file unzip : c:\lttrn\api\LT1800Test\webapps\LumberTrack\WEB-INF\openedge\Notes.r trace: file unzip : c:\lttrn\api\LT1800Test\webapps\LumberTrack\WEB-INF\openedge\OpenEdge\Security\Realm\HybridRealm.r trace: file unzip : c:\lttrn\api\LT1800Test\webapps\LumberTrack\WEB-INF\openedge\OpenEdge\Security\Realm\OERealmDefs.r trace: file unzip : c:\lttrn\api\LT1800Test\webapps\LumberTrack\WEB-INF\openedge\OpenEdge\Security\Util\Properties.r trace: file unzip : c:\lttrn\api\LT1800Test\webapps\LumberTrack\WEB-INF\openedge\Printing.r trace: file unzip : c:\lttrn\api\LT1800Test\webapps\LumberTrack\WEB-INF\openedge\PurchaseOrders.r trace: file unzip : c:\lttrn\api\LT1800Test\webapps\LumberTrack\WEB-INF\openedge\PurchaseOrdersHandler.r trace: file unzip : c:\lttrn\api\LT1800Test\webapps\LumberTrack\WEB-INF\openedge\SalesOrders.r trace: file unzip : c:\lttrn\api\LT1800Test\webapps\LumberTrack\WEB-INF\openedge\SalesOrdersHandler.r trace: file unzip : c:\lttrn\api\LT1800Test\webapps\LumberTrack\WEB-INF\openedge\Setup.r trace: file unzip : c:\lttrn\api\LT1800Test\webapps\LumberTrack\WEB-INF\openedge\SetupHandler.r trace: file unzip : c:\lttrn\api\LT1800Test\webapps\LumberTrack\WEB-INF\openedge\Shipments.r trace: file unzip : c:\lttrn\api\LT1800Test\webapps\LumberTrack\WEB-INF\openedge\ShipmentsHandler.r trace: file unzip : c:\lttrn\api\LT1800Test\webapps\LumberTrack\WEB-INF\openedge\spaservice.properties trace: file unzip : c:\lttrn\api\LT1800Test\webapps\LumberTrack\WEB-INF\openedge\Tags.r trace: file unzip : c:\lttrn\api\LT1800Test\webapps\LumberTrack\WEB-INF\openedge\TransactionLog.r trace: file unzip : c:\lttrn\api\LT1800Test\webapps\LumberTrack\WEB-INF\openedge\UserLt.r trace: file unzip : c:\lttrn\api\LT1800Test\webapps\LumberTrack\WEB-INF\openedge\UserLtHandler.r trace: file unzip : c:\lttrn\api\LT1800Test\webapps\LumberTrack\WEB-INF\openedge\Vendors.r trace: file unzip : c:\lttrn\api\LT1800Test\webapps\LumberTrack\WEB-INF\openedge\VendorsHandler.r trace: file unzip : c:\lttrn\api\LT1800Test\webapps\LumberTrack\WEB-INF\openedge\WorkOrders.r trace: file unzip : c:\lttrn\api\LT1800Test\webapps\LumberTrack\WEB-INF\openedge\WorkOrdersHandler.r verbose: found WEB service LumberTrack.Inventory.handlers trace: file unzip : c:\lttrn\api\LT1800Test\webapps\LumberTrack\WEB-INF\tlr\LumberTrack.Inventory.handlers verbose: found WEB service LumberTrack.PurchaseOrders.handlers trace: file unzip : c:\lttrn\api\LT1800Test\webapps\LumberTrack\WEB-INF\tlr\LumberTrack.PurchaseOrders.handlers verbose: found WEB service LumberTrack.SalesOrders.handlers trace: file unzip : c:\lttrn\api\LT1800Test\webapps\LumberTrack\WEB-INF\tlr\LumberTrack.SalesOrders.handlers verbose: found WEB service LumberTrack.Setup.handlers trace: file unzip : c:\lttrn\api\LT1800Test\webapps\LumberTrack\WEB-INF\tlr\LumberTrack.Setup.handlers verbose: found WEB service LumberTrack.Shipments.handlers trace: file unzip : c:\lttrn\api\LT1800Test\webapps\LumberTrack\WEB-INF\tlr\LumberTrack.Shipments.handlers verbose: found WEB service LumberTrack.Users.handlers trace: file unzip : c:\lttrn\api\LT1800Test\webapps\LumberTrack\WEB-INF\tlr\LumberTrack.Users.handlers verbose: found WEB service LumberTrack.Vendors.handlers trace: file unzip : c:\lttrn\api\LT1800Test\webapps\LumberTrack\WEB-INF\tlr\LumberTrack.Vendors.handlers verbose: found WEB service LumberTrack.WorkOrders.handlers trace: file unzip : c:\lttrn\api\LT1800Test\webapps\LumberTrack\WEB-INF\tlr\LumberTrack.WorkOrders.handlers trace: file unzip : c:\lttrn\api\LT1800Test\webapps\LumberTrack\WEB-INF\tlr\Merge.template trace: file unzip : c:\lttrn\api\LT1800Test\webapps\LumberTrack\WEB-INF\tlr\oeabl_tlr trace: done verbose: reading handler list for web application LumberTrack trace: application - LT1800Test trace: webApp - LumberTrack verbose: reading current handler mappings trace: looking for handler1 trace: adding unique entry for /v1/Inventory at 1 verbose: found InventoryHandler:/v1/Inventory trace: looking for handler2 trace: adding unique entry for /v1/PurchaseOrders at 2 verbose: found PurchaseOrdersHandler:/v1/PurchaseOrders trace: looking for handler3 trace: adding unique entry for /v1/SalesOrders at 3 verbose: found SalesOrdersHandler:/v1/SalesOrders trace: looking for handler4 trace: adding unique entry for /v1/Setup at 4 verbose: found SetupHandler:/v1/Setup trace: looking for handler5 trace: adding unique entry for /v1/Shipments at 5 verbose: found ShipmentsHandler:/v1/Shipments trace: looking for handler6 trace: adding unique entry for /v1/Users at 6 verbose: found UserLtHandler:/v1/Users trace: looking for handler7 trace: adding unique entry for /v1/Vendors at 7 verbose: found VendorsHandler:/v1/Vendors trace: looking for handler8 trace: adding unique entry for /v1/WorkOrders at 8 verbose: found WorkOrdersHandler:/v1/WorkOrders trace: looking for handler9 trace: Copying c:\lttrn\api\LT1800Test/conf/openedge.properties to c:\lttrn\api\LT1800Test/conf/openedge.tmp verbose: processing handlers for LumberTrack.Inventory service verbose: handler class is InventoryHandler verbose: replacing mapping for /v1/Inventory trace: property - +LT1800Test.LumberTrack.WEB.handler1=InventoryHandler:/v1/Inventory trace: Moving (1) c:\lttrn\api\LT1800Test/conf/openedge.tmp to c:\lttrn\api\LT1800Test/conf/openedge.properties verbose: processing handlers for LumberTrack.PurchaseOrders service verbose: handler class is PurchaseOrdersHandler verbose: replacing mapping for /v1/PurchaseOrders trace: property - +LT1800Test.LumberTrack.WEB.handler2=PurchaseOrdersHandler:/v1/PurchaseOrders trace: Moving (1) c:\lttrn\api\LT1800Test/conf/openedge.tmp to c:\lttrn\api\LT1800Test/conf/openedge.properties trace: Moving (2) c:\lttrn\api\LT1800Test/conf/openedge.tmp to c:\lttrn\api\LT1800Test/conf/openedge.properties trace: Moving (3) c:\lttrn\api\LT1800Test/conf/openedge.tmp to c:\lttrn\api\LT1800Test/conf/openedge.properties trace: Moving (4) c:\lttrn\api\LT1800Test/conf/openedge.tmp to c:\lttrn\api\LT1800Test/conf/openedge.properties trace: Moving (5) c:\lttrn\api\LT1800Test/conf/openedge.tmp to c:\lttrn\api\LT1800Test/conf/openedge.properties trace: Moving (6) c:\lttrn\api\LT1800Test/conf/openedge.tmp to c:\lttrn\api\LT1800Test/conf/openedge.properties trace: Moving (7) c:\lttrn\api\LT1800Test/conf/openedge.tmp to c:\lttrn\api\LT1800Test/conf/openedge.properties trace: Moving (8) c:\lttrn\api\LT1800Test/conf/openedge.tmp to c:\lttrn\api\LT1800Test/conf/openedge.properties trace: Moving (9) c:\lttrn\api\LT1800Test/conf/openedge.tmp to c:\lttrn\api\LT1800Test/conf/openedge.properties trace: Moving (10) c:\lttrn\api\LT1800Test/conf/openedge.tmp to c:\lttrn\api\LT1800Test/conf/openedge.properties deploysvc: c:\lttrn\api\LT1800Test\conf\openedge.tmp execution failed proenv>
